jc4d Posted September 20, 2015 Share Posted September 20, 2015 Hi all, I´m trying to create a text on a rectangle but the thing is that I would like to set the text Horiz. Align to Center as default but I can´t find a way to do it. Cheers, Juan Quote Link to comment
Kevin McAllister Posted September 20, 2015 Share Posted September 20, 2015 Use the Set Text Properties node found under Text. If you click on Description in the OIP with the node selected it lists off all the parameters. I've attached an example. Kevin Quote Link to comment
jc4d Posted September 20, 2015 Author Share Posted September 20, 2015 Awesome, thank you. So the int node given number controls the dropdown menu selection. Maybe is not the right terminology Cheers, Juan Quote Link to comment
