Marionette Node to insert symbols in rows
This is a great example of a simple "Bread and Butter" script as I like to call them, a script that automates a simple day to day task and saves the user a few minutes. Most people think of flashy, curvy geometry when you mention graphical scripting. I think the fact that Marionette is integrated into VW and allows these day to day tasks to be automated is really useful. Thanks for sharing.
  • 6 months later...
#python code. Copy this in your existing node. It just lists ALL Symbols without caring about symbol folders. Like always whithout warranty.
@Marionette.NodeDefinition
class Params(metaclass = Marionette.OrderedClass):
this = Marionette.Node( "InsertAllSymDefinitions" )
this.SetDescription( 'Shows all Symbol definition' )
offset = Marionette.PortIn( (1), "offset" )
offset.SetDescription( "offset of columns and rows" )
columns = Marionette.PortIn( 4 )
columns.SetDescription( "Number of columns" )
angle = Marionette.PortIn( (0) )
angle.SetDescription( "angle" )
symbols = Marionette.PortOut()
symbols.SetDescription( "the created symbol preview" )
this.SetLinksObjects()
def RunNode(self):
versatz = self.Params.offset.value
spalten = self.Params.columns.value
angle = self.Params.angle.value
x=0;y=0;zeile=0;c=1
symnames=[]
res_list,num_items=vs.BuildResourceList( 16, 0, '')
for i in range(num_items):
	res=vs.GetResourceFromList(res_list, i)
	if res !=vs.Handle(0):
		t=vs.GetType(res)
		if t ==16:
			symnames.append(vs.GetName(res))
#vs.AlrtDialog(str(symnames))
for n in symnames:
	vs.Symbol(n,x,y,angle)
	vs.Locus(x,y)
	x=x+versatz
	zeile=int(c/spalten)
	y=zeile*versatz
	if c % spalten ==0:
		x=0
	c=c+1
self.Params.symbols.value = vs.LNewObj()
  • 7 years later...
Hi @DomC,
ich habe diesen Code eingefügt, leider ergibt der Node keine Symbole... Ich komme leider nicht drauf wieso das nicht funktioniert?
def RunNode(self):
	x=0;y=0;zeile=0;c=1
	symnames=[]
			t=vs.GetType(res)
			if t ==16:
	for n in symnames:
			vs.Locus(x,y)
			x=x+versatz
			y=zeile*versatz
			if c % spalten ==0:
				x=0
			c=c+1
Oh, this is an old code and not very nice one. Without testing:
1. The vs.GetType should replaced by:
vs.GetTypeN(res)
2. The node returns not the Symbol Name. That means the node itself insert the Symbol. In fact it looks, like the output just returns the last inserted symbol. Which means the node should insert the symbols in the number of rows and should do the job but not returning the resulting symbol handles. With that node, you can't use the output useful disconnect symbol node and print debug node.
