jcaia Posted September 15, 2015 Share Posted September 15, 2015 So I love VW's stair Dbx, but is their a way to mix "styles" somewhat? My issue is I have projects where I build a combination of "solid" and "stringer outside" types - which is actually fairly common. It would be all too cool if there was some way to get options for both, but is my only solution to either model the stringer or solid under the risers? I've attached the menu options highlighted, along with an example of the type of stair I am trying to model. Thanks! Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted September 15, 2015 Vectorworks, Inc Employee Share Posted September 15, 2015 Is there a standardized name for that stair type? I don't believe its directly possible in a single stair object with the current Stair tools, but I am writing up the feature request now. Quote Link to comment
jcaia Posted September 15, 2015 Author Share Posted September 15, 2015 Yeah - I couldnt see a way to do that either in 1 stair object. I was able to create 2 stair objects and have them exist in the same space for a quick work-around, but it would be great if we could get added control here. Again, this is a fairly typical design type. Thanks! Quote Link to comment
Guest Wes Gardner Posted September 15, 2015 Share Posted September 15, 2015 You might call that a Helical Stair Quote Link to comment
