change value of record field in symbol definition
michaelk
Can someone point me in the right direction?
I have a script that successfully
Creates a record format
Creates a symbol folder
Creates a symbol
Attaches the record format to the symbol
Now I'd like to change the values in the fields attached to a symbol. (Eventually, several symbols will use this record format.) The symbol has not been inserted into the drawing. I want to change the values in the symbol definition.
SetRField(symbolHand, nameOfRecordFormat, nameOfField,'This is a test'); doesn't seem to do it.
Is this possible? Do I need to create a different record format with default values for each symbol?
Any ideas?
Thanks!
mk
How can I make sure?
The symbol is not inserted into the drawing. I'm capturing the handle to the symbol with a GetObject immediately after the symbol is created.
symbolHand := GetObject(nameOfSymbol);
Even after SetRField(symbolHand, nameOfRecordFormat, nameOfField,'This is a test'); the symbol definition still has the default record format values.
thanks
mk
  • 5 years later...
