Popular Post Ozzie Posted August 28, 2015 Popular Post Share Posted August 28, 2015 Does this make sense? www.screencast-o-matic.com/watch/coju6ofpUG D 7 Quote Link to comment
zoomer Posted August 28, 2015 Share Posted August 28, 2015 (edited) Yes makes sense. The way I was used to use a Scale Tool before VW was : - select Object(s!) to scale - click on Scale Center/Origin - click on point to give current length from Center - click on point to give new length from Center done. Of course there are options to restrict scaling to one or more axis Important is to be able to choose a special Center at all, and optional set that Center to the local Center of each object, so that you select and scale all of your similar trees at one time. Edited August 28, 2015 by zoomer 1 Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted September 15, 2015 Vectorworks, Inc Employee Share Posted September 15, 2015 Yes indeed, it took some head whacking for users to make me understand the benefit, but got it submitted here: https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=194306 Adding this thread to that request. 2 Quote Link to comment
Ozzie Posted September 15, 2015 Author Share Posted September 15, 2015 Coolies and ta 1 Quote Link to comment
MarcU Posted January 10, 2017 Share Posted January 10, 2017 (edited) On 28.8.2015 at 1:32 PM, zoomer said: Yes makes sense. The way I was used to use a Scale Tool before VW was : - select Object(s!) to scale - click on Scale Center/Origin - click on point to give current length from Center - click on point to give new length from Center done. Of course there are options to restrict scaling to one or more axis Important is to be able to choose a special Center at all, and optional set that Center to the local Center of each object, so that you select and scale all of your similar trees at one time. I agree, this would be really great and intuitive, like in AutoCAD. As OZZie says/shows in his screencast: Another very helpful and easyer to realize solution within the existing scale objects tool, maybe as a first step, would be another measuring tool for the new length (see attached screenshot). Why? -> often you have just some random object as a reference length and not a dimension. In this case I find it very unhandy if you: a) first have to measure this reference object outside the dialog, b) then write down the measurment somewhere c) open the scaling dialog d) and then write it in to the dialog manually again. What do other people think about this? What do you think, Jim? I requested this also at Computerworks Switzerland. Would be great to have this soon! Sorry for german dialog - hope it looks similar in the international version. Here how it might look: Edited January 10, 2017 by SwissMarc 3 Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted January 10, 2017 Vectorworks, Inc Employee Share Posted January 10, 2017 Absolutely agree, I'll bump the wishlist item again with the new forum link. (Interested parties should feel free to vote this thread up at the top left!) VE-93326 Quote Link to comment
MarcU Posted January 10, 2017 Share Posted January 10, 2017 Great! You're pretty fast, thanks! looking forward to that. Quote Link to comment
Markvl Posted January 11, 2017 Share Posted January 11, 2017 Totally makes sense. Great Idea @Ozzie 1 Quote Link to comment
nca777 Posted March 25, 2017 Share Posted March 25, 2017 On 1/10/2017 at 0:08 PM, MarcU said: I agree, this would be really great and intuitive, like in AutoCAD. As OZZie says/shows in his screencast: Another very helpful and easyer to realize solution within the existing scale objects tool, maybe as a first step, would be another measuring tool for the new length (see attached screenshot). Why? -> often you have just some random object as a reference length and not a dimension. In this case I find it very unhandy if you: a) first have to measure this reference object outside the dialog, b) then write down the measurment somewhere c) open the scaling dialog d) and then write it in to the dialog manually again. What do other people think about this? What do you think, Jim? I requested this also at Computerworks Switzerland. Would be great to have this soon! Sorry for german dialog - hope it looks similar in the international version. Here how it might look: Learning quickly here and running up against what seem to be many of the sam requests as other users. Please consider this post a +1 on this request. Ideally scale and rotate tools would take a hint from AutoCAD's "scale reference" and "rotate reference" commands. Thank You. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted March 27, 2017 Vectorworks, Inc Employee Share Posted March 27, 2017 On 3/24/2017 at 8:05 PM, nca777 said: Learning quickly here and running up against what seem to be many of the sam requests as other users. Please consider this post a +1 on this request. Ideally scale and rotate tools would take a hint from AutoCAD's "scale reference" and "rotate reference" commands. Thank You. Make sure you've upvoted it at the top left of the original post: (If you already did, then please ignore, just making sure everyone knows about it.) Quote Link to comment
G Troyer Posted November 20, 2017 Share Posted November 20, 2017 On 8/28/2015 at 6:25 AM, Ozzie said: Does this make sense? www.screencast-o-matic.com/watch/coju6ofpUG D I have been wishing for this common sense feature for a long time and just realized this morning that it was added to 2018. Thanks Ozzie and Vectorworks! Quote Link to comment
collins Posted March 6, 2021 Share Posted March 6, 2021 I can't find where this thread is to be upvoted, I guess because it's an old version? But is there a simple scale tool that doesn't require heading to the drop down menu and typing in etc etc. Also, it would be great that the scaling occurred from the point at which the measurements took place. As in you are scaling the object from a point rather than the object scaling to the new desired size but jumping into a random nearby position. Quote Link to comment
