JoshW Posted August 21, 2015 Share Posted August 21, 2015 I am trying to create separate door schedules for interior and exterior doors, but I am having trouble with the criteria settings to get the worksheet to function properly. The criteria I have currently looks something like this: Layer is 0-Basement Record Door is present Field Value On Schedule = TRUE Field Value Location = EXTERIOR It seems that the last piece of criteria is not being used. No matter what I type in for the Location field, it will not cull out the doors that say "interior" Am I missing something, or should they be in a different order? Quote Link to comment
michaelk Posted August 21, 2015 Share Posted August 21, 2015 I think this is a problem with the GUI in the database criteria. The worksheet interprets your criteria like this: Layer is 0-Basement AND Record Door is present AND (Field Value On Schedule = TRUE OR Field Value Location = EXTERIOR) It only needs one field value to be true. There's no way in the Edit Criteria dialog box to choose if you want both field values or either one. The way to fix it is to get to that Edit Criteria… dialog box. Click Cancel. Look in the formula bar. It will say something like = DATABASE(… Look for the part that says (('Door'.'OnSched'=TRUE) | ('Door'.'Location'='Interior')))) Change the '|' to '&' [in logic speak, '|' (called a pipe) = OR and '&' (ampersand) = AND] That will force the database criteria to select doors that have BOTH 'on schedule' and Interior Keep an eye on it. I haven't kept track of what future changes in the database criteria will cause it to revert back to '|'. But it can happen. hth mk Quote Link to comment
JoshW Posted August 21, 2015 Author Share Posted August 21, 2015 Thanks!! I'm glad that's an intuitive and easy to find solution... :tired: Quote Link to comment
gester Posted September 14, 2015 Share Posted September 14, 2015 i think we'll be moving to ifc properties instead of concentrating on data records. where can i find some explanations on the ifc props in the worksheets/database? thx in advance. rob Quote Link to comment
