Guest Posted March 17, 2003 Share Posted March 17, 2003 For users having problems with the shift-select or ctrl-select, or just shift problem in Vw and other applications, it is recommended to run the combo updater to OS 10.2.4. There are instances in applications where the shift key does not capitalize a charachter, shift+Select does not select more than one item, or ctrl select does not behave as it should. These problems have been demonstrated in VW, Word and many other applications. It should be resolved by updating (if not already) or re-updating to OS 10.2.4 using the combo updater. The combo updater can be found on Apple's website. Quote Link to comment
