Christian Fekete Posted August 14, 2015 Share Posted August 14, 2015 (edited) Just reinstalled VW13 on a new Macbook Pro and the tool menus fonts look weird. Any suggestions on how to fix this? Thank you CF Edited August 14, 2015 by Christian Fekete Quote Link to comment
rDesign Posted August 14, 2015 Share Posted August 14, 2015 It's probably that Vw2013 cannot take full advantage of the MacBook Pro's high-resolution Retina display. Unless you upgrade to Vw2015 (which has been optimized for Retina), you'll be stuck with it. VwKB : Retina Display Compatibility - Mac OSX Apple Support Communities : Pixelated text and graphics in MacBook Pro Retina Quote Link to comment
Vectorworks, Inc Employee Vectorworks - Admin Posted August 14, 2015 Vectorworks, Inc Employee Share Posted August 14, 2015 ^ This is correct. 2015 and later will be the only versions to support Retina and other high res displays on Mac. Quote Link to comment
Christian Fekete Posted August 17, 2015 Author Share Posted August 17, 2015 My iMac has retina and this does not happen though. Quote Link to comment
Vectorworks, Inc Employee Vectorworks - Admin Posted August 17, 2015 Vectorworks, Inc Employee Share Posted August 17, 2015 It depends which level of scaling is needed, also on the aspect ratio of the monitor itself. OS X decides which 5 or so levels of scaling to give you based on the display. "Unsupported" doesn't necessarily mean it wont work, just that it will not be fixed in that particular version IF it does not work. Quote Link to comment
