drmdzh Posted August 13, 2015 Share Posted August 13, 2015 I am using viewports to lay out a drafting on a sheet layer - the viewports are taken from a 3D model. Why can't I use the radial dimension tool (archways, moulding etc)? Vectorworks "knows" what I am trying to dimension is an arc because it will show me the arc center when I hover over the object, but the dimension tool says "can only be used on circles". What is the work-around? Right now, I am tracing the line using the arc tool when I am in "Edit annotation", but this seems rather silly. Thanks. Quote Link to comment
JBenghiat Posted August 13, 2015 Share Posted August 13, 2015 David, It works for me. Are you in an orthogonal view? That is the only view that will give you accurate dimensions in viewports. To see dimensions in 3D planes, you need to make them in design layers. I did see the alert you describe when in a perspective view. The text is not really relevant to the reason you have the error. HTH, Josh Quote Link to comment
drmdzh Posted August 13, 2015 Author Share Posted August 13, 2015 Yes, I am in orthogonal view. Sorry, but what do you mean "To see dimensions in 3D planes, you need to make them in design layers." ? I have a 3D model I created in a design layer and am creating viewports in a sheet layer to dimension. Not sure what you were asking. thanks Quote Link to comment
Kevin McAllister Posted August 13, 2015 Share Posted August 13, 2015 I think part of the issue is probably that David is using VW2014. This improved greatly in VW2015 though I still find its an issue with more complex 3d solids. Also, 3d views can be an issue as Josh says. If you post a simple example someone could try it for you in VW2015 to see if the problem is your version or the situation in which you're trying to use radial dimensions. KM Quote Link to comment
drmdzh Posted August 13, 2015 Author Share Posted August 13, 2015 Sorry, didn't update my signature... now in 2015 and still and issue - not on every solid, but yes, the more complex ones. I'll post an example when I get a break. Thanks. Quote Link to comment
JBenghiat Posted August 13, 2015 Share Posted August 13, 2015 Viewport dimensioning is in the screen plane, and as such only works properly in an orthogonal view aligned to the surface you want to dimension. If you want to show dimensions of 3D objects where the surfaces do not align to the screen plane, you have to create the dimensions in a design layer, not in the viewport. If you can dimension the arc in a design layer but not the viewport, this is likely the source of the issue. -Josh Quote Link to comment
Kevin McAllister Posted August 13, 2015 Share Posted August 13, 2015 I find that there are often examples where VW highlights the curve you want to dimension but then dimensioning fails with this error. This occurs even when the viewport is in a true view (ie. front, back, top, side) and the object is aligned with the axes. Its almost always with complex solids (ie. solid additions, solid subtractions) or with Extrude Along Path objects. It drives me a bit crazy because VW seems to be able to clearly identify the curve (ie. highlight it) but can't actually dimension it. KM 1 Quote Link to comment
drmdzh Posted August 13, 2015 Author Share Posted August 13, 2015 I AM in orthogonal view and the object IS aligned to the view. I have uploaded a sample from the project I'm working on. Other examples include simple extruded archways, this one was created using extrude along path. Everything dimensions just fine, but not the radials. Thanks for all the responses. Quote Link to comment
AlanW Posted August 26, 2015 Share Posted August 26, 2015 I think the problem is that there is no longer a circle or arc in you drawing. the profile at the top is a 3d shape so you can only pick the corners. Workaround is to draw a 3point arc to follow your curve in annotations and you then have a centre point to dimension to. HTH Quote Link to comment
lcda Posted December 20, 2016 Share Posted December 20, 2016 (edited) its so stupid all of these years an i can NOT use radial dimension on viewports UNBELIEVABLE!!!! Edited December 20, 2016 by lcda 1 Quote Link to comment
Stéphane Posted May 19, 2022 Share Posted May 19, 2022 Having the same issue on a 2D plan VP. Hasn't it been fixed yet ? Quote Link to comment
royshearer Posted December 9, 2024 Share Posted December 9, 2024 I had a similar issue - I discovered that I had slightly rotated my workplane, and my viewport had ended up out of alignment with the workplane that the objects I was dimensioning were drawn in. I fixed it by rotating the objects to match the viewport and then could dimension arcs and angles fully. Hope that helps! Quote Link to comment
