screw and nut object
I see the same. Looks like a bug in the Fastener Tool.
Fastener Tool from the Fastener Tool Set:
I made a socket head cap screw (the default) and duplicated 25 times with the Move By Points Tool. Select all. Adjustments to the OIP length parameter changes all of them as expected. Changing the Configuration parameters, eg the bolt type or diam, only changes one of them. If several are selected, instead of all, only one responds to changes in the config parameter.
The Bolt and Screw tools in the Detail Tool Set seem to work as expected. Multiple copies of them respond to adjustments in the OIP parameter fields. But they do not have a config pull down.
Fastener Tool bug must be some problem with the Configuration pull down menu in the OIP.
Submitting a bug report for US version, citing this thread.
BAS, can you send one to your distributor?
-B
