J. Franks Posted July 29, 2015 Share Posted July 29, 2015 I have a 15" Macbook Pro linked to a larger monitor/TV display. I've successfully used this dual-monitor setup for Vectorworks in the past, with the main drawing on my laptop display and the palettes shuffled over and arranged on the external display. The palette positions were saved and they more or less always stayed there, unless of course I disconnected the monitor. I've rearranged things and want to use the larger monitor as my main drafting window, so today I set up the document and moved all my palettes over to the MacBook display. They won't stay there. If I click out of Vectorworks to another program, the palettes move themselves over to the other display when I come back. The only way I can keep my palettes on the Macbook display is if my drawing window is there too. This behavior occurs regardless of whether or not I have "Displays have separate spaces" checked. I upgraded to VW 2015 SP4 today, but it was happening in SP3 as well. Running OS 10.9.5. Am I missing something? Am I trying to do something that won't work? Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted July 29, 2015 Vectorworks, Inc Employee Share Posted July 29, 2015 I have seen this most often when using multiple spaces, Vectorworks often resets and regathers the palettes back into the main screen or to one of the screens on the main space. Most likely this isnt anything you've done wrong, I've submitted a bug report on this behavior. I will add this thread to it. Quote Link to comment
Nicholas Kargel Posted August 3, 2015 Share Posted August 3, 2015 A workaround that might work, which I think I learned of on this forum: there's a little app called "stay" that will remember window locations for different combinations of external monitors, and recall them on command. Quote Link to comment
Art V Posted August 4, 2015 Share Posted August 4, 2015 I don't know how it works on Apple machines, but in Windows you can specify the main and secondary screen. Depending on the driver it sometimes gets changed for whatever reason after connecting/disconnecting some monitors/projectors then your windows will end up on the wrong screen or may not be visible at all when you are back on a single screen/monitor. You may want to check your display settings for which screen is defined as main and which as secondary and whether this has changed when you run into this problem. Attaching a secondary monitor may be necessary to put things back to normal when changing the settings. Quote Link to comment
LZRFLP Posted February 22, 2017 Share Posted February 22, 2017 I had a similar issue. For me it was the Windows Monitor change size from 100 % to 125 % which made it buggy for me. One monitor had 125%, the other had 100%. Then it automatically sent pallets to strange places when trying to adjust them. FIXED when I put both monitors to 125 %. Quote Link to comment
Ed Wachter Posted November 17, 2021 Share Posted November 17, 2021 6 Years later, and this appears to still be an issue. I am now using VW2021 on Mac OS 10.14.6 (Mohave). I just started using two monitors for the first time in a several years. We will be replacing our computers with new Macs and using VW2022 by the end of the year. Hopefully that will resolve the problem. Thanks for all your comments above. Ed Quote Link to comment
