It is possible to give a description of a class or layer in the class/layer manager.
However it only seems to be visible when hovering over the class or layer in the organisation dialog window or in the navigation palette.
It would be nice if it would be directly visible as a column in both the organisation dialog window and the navigation palette instead of having to hover over each class/layer.
And if possible also an option to show a description popup when hovering over a class/layer in the class selection dropdown menu in the main menu bar as well.
Once in a while I run into a project description that also defines the drawing layers (classes) by numbers only. Then it would be nice if the class/layer descriptions could be directly visible instead of of hunting through the numbers by hovering over them until you find the matching description.
Art V
6 answers to this question
