michaelk Posted July 26, 2015 Share Posted July 26, 2015 This is just me poking around trying to learn more VS. I was looking up ASCII values. I always forget that carriage return is chr(13). I noticed that the extended characters (128-255) on web tables differed from the what vectorworks returned. The VS Language Guide has a reference to ISO 8859-1. That's yet a third different set of values for 128-255. I'll attach a examples Anyone know what's going on? Thanks mk Quote Link to comment
Hippocode Posted July 26, 2015 Share Posted July 26, 2015 (edited) If I remember correct it returns a different character when you use a concat function over the original chr(xx) on the Windows platform. Not sure if something similar happens on OsX. Edited July 26, 2015 by hippothamus Quote Link to comment
michaelk Posted July 26, 2015 Author Share Posted July 26, 2015 I don't think I'm seeing it on OSX. Are you saying that Message(chr(176),chr(177)); returns something different from Message(CONCAT(chr(176),chr(177)));? mk Quote Link to comment
Hippocode Posted July 27, 2015 Share Posted July 27, 2015 I don't think I'm seeing it on OSX. Are you saying that Message(chr(176),chr(177)); returns something different from Message(CONCAT(chr(176),chr(177)));? mk Yes, I just confirmed it on my old computer where Windows will return a different symbol for the upper 128 symbols when you use a concat function over it. This doesn't appear on OsX. I wrote this simple script not only to help me find any symbol I need but also shows the difference with using the concat function in the last column. On OsX both symbol columns are the same. PROCEDURE ASC; VAR BladHd :HANDLE; i :INTEGER; WsName :STRING; BEGIN WsName:='ASCII'; BladHd:=GetObject(WsName); IF BladHd = NIL THEN BEGIN BladHd:=CreateWS(WsName,256,3); SetWsCellFormula(BladHd,1,1,1,1,'ASCII Number'); SetWsCellFormula(BladHd,1,2,1,2,'ASCII Symbol'); SetWsCellFormula(BladHd,1,3,1,3,'ASCII concat(Symbol)'); END; FOR i:=1 TO 255 DO BEGIN SetWsCellFormula(BladHd,i+1,1,i+1,1,concat(i)); SetWsCellFormula(BladHd,i+1,2,i+1,2,Chr(i)); SetWsCellFormula(BladHd,i+1,3,i+1,3,concat(Chr(i))); END; END; Run(ASC); Quote Link to comment
Vectorworks, Inc Employee klinzey Posted July 27, 2015 Vectorworks, Inc Employee Share Posted July 27, 2015 Anything over 127 is questionable about how it will display or processed by Vectorworks. Typically the Mac extended characters works best. In general we try to avoid using the extended characters set and often have a test for Mac/Win and use different characters and expose them a plug-in strings. We avoid using the extended characters set for things like symbol names because they have caused too many problems over the years and often display very differently depending on the font being used. Quote Link to comment
