lcda
Vectorworks 2016
3 NEW FEATURE SUGESTIONS FOR FAST DRAWING
1.- An amazing feature i saw in another cad to draw very fast
is the possibility of input numerical data on info palette with 2 clicks
just like the way is done when you input the current distance on scaling objects
bot you can do it for EVERYTHING!!!
2.- I insists toggle auto join walls must be on the main window also toggle group view and line thickness
3.- the attributes palette should be in info palette with possibility of making object all class attributes
1 answer to this question
1) Apologies, I do not understand your request. Do you mean let all objects have a symmetrical/Asymmetrical scaling factor like Symbols do?
2) Zoom Line Thickness and Auto Join Walls are already quick pref options, I think Line Thickness setting visibility on by default in 2015 and possibly earlier. (Please edit your signature to reflect your OS and Vectorworks Version similarly to mine to make things smoother in the future)
3) The attribute can already make all attributes by class, there is a small button at the very bottom of the attribute palette with an arrow pointing down in versions other than Fundamentals, click it and select "Make All Attributes By Class".
What would be the benefit of adding the attributes palette to the object info palette?
