Changing window types?
Brooklyn
I'm just beginning to use the Window and Door insertion tools and am having a problem.
When I open the 'Create Object' menu for windows and enter the type and parameters of the new window type I want, click OK, and try to insert it . . . VW inserts the PREVIOUS window type, not the one I thought I had just created.
Is there any way to have VW 'forget' the previous one?
Thanks!
10 answers to this question
Double clicking the tool to get the Create Object window just does a one-off. If you select the Window tool, then click the Preferences button and customize your settings there, then place multiple windows, it will use those settings as the default until you change it.
