oli w Posted July 8, 2015 Share Posted July 8, 2015 Hi, I'm creating an object (high level canopy) that needs to be dotted on the plan viewport, but solid on the ceiling plan viewport. Is there an easier way or doing this without simply duplicating the item and putting it on different classes? Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted July 8, 2015 Vectorworks, Inc Employee Share Posted July 8, 2015 I believe you are looking for Viewport Class Overrides, which let you alter the class attributes only within one or a selection of viewports: http://app-help.vectorworks.net/2015/NNA/eng/index.htm#t=VW2015_Guide%2FViewports%2FChanging_the_Class_Properties_of_Sheet_Layer_or_Design_Layer.htm The above covers the basics I believe, if it doesn't make sense let me know and I can provide an example. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted July 8, 2015 Vectorworks, Inc Employee Share Posted July 8, 2015 I am fairly certain the majority of this can be done in Vectorworks 2011 as well, if that is the version you are still working with. Quote Link to comment
AlanW Posted July 9, 2015 Share Posted July 9, 2015 If you are looking at a 3D object you can (as I have just found out) convert the object to an Auto Hybrid and set the cutting plane to 0, then in top plan mode you only see the 2d section which you can control in the viewport class option. Quote Link to comment
oli w Posted July 16, 2015 Author Share Posted July 16, 2015 That's exactly what I was looking for Jim. Thanks Quote Link to comment
