Acip79 Posted June 25, 2015 Share Posted June 25, 2015 Hi there, I am new to Vectorworks BIM. Is there any feature similar to clash detection in Revit in VW? Or i need to export it to IFC object and need a 3rd-party software to run the test. TQ. Quote Link to comment
Guest Wes Gardner Posted June 25, 2015 Share Posted June 25, 2015 (edited) Hey There, You are correct, you will need to export via IFC. We typically suggest Solibri, either the free version - Solibri Model Viewer or the more "industrial strength" version - Solibri Model Checker. Solibri is cross-platform. Wes Edited June 25, 2015 by Wes Gardner Quote Link to comment
Acip79 Posted June 26, 2015 Author Share Posted June 26, 2015 Thanks for your advice. Will there be any data lost either model from VW or Revit since my other consultants are using Revit. Quote Link to comment
Vincent C Posted June 26, 2015 Share Posted June 26, 2015 (edited) Tekla has a free IFC checker too.... http://www.teklabimsight.com/ Edited June 26, 2015 by Vincent C Quote Link to comment
gester Posted June 27, 2015 Share Posted June 27, 2015 your design consultants may encounter troubles while importing your vw ifc export into revit in case you've used boolean operations (aec > fit walls to objects). the import of ifc data from revit may be offset in your vw file - advise them to use the gpl (open source) ifc translator for revit, not the native one from autodesk, and define the model origin exactly. rob Quote Link to comment
