Blissab Posted June 4, 2015 Share Posted June 4, 2015 Hello Everyone, Please bear with me. This is the problem: 1. Have drawn a rectangle: 1-inch wide x 6-inches high. 2. Trying to drawn a simple line from the lower-left corner to the upper-right corner. Line will not connect to the end point of the upper-right corner. The line command seems to be locked into an angular dimension of either 90-degrees or 60-degrees. 3. I have the Snap to Object; Snap to Intersection; Smart Points; Smart Edge and Snap to Angle activated. I've also tried this function with all the snaps de-activated. I know I've missing some obvious and simple function...any ideas? Thank you, AB Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted June 4, 2015 Vectorworks, Inc Employee Share Posted June 4, 2015 The Line tool has two modes, one of them, "Constrained", locks you to set angles. I believe you want "Unconstrained" mode and "Vertex" mode enabled to draw what you're drawing. Quote Link to comment
Blissab Posted June 4, 2015 Author Share Posted June 4, 2015 Thank you, Jim! I knew it was something obvious. AB Quote Link to comment
