domer1322 Posted June 4, 2015 Share Posted June 4, 2015 I have an odd door problem. Look at the images of the door opening in a wall, and you'll see an area that is colored white. Then look at the close-up of the jamb (file "door 2") and you'll see the white area doesn't really correspond to anything (it is not the width of the wall, for instance) I can't get rid of it. I've tried many settings in the OIP for this door (it is an un-cased opening, no leaf, with a rounded arch top). When I put my curser over the edges of the white area, it shows "object" as if I could snap to it, but I can not select it. Please forward any suggestions. Thanks. Quote Link to comment
AlanW Posted June 4, 2015 Share Posted June 4, 2015 Is your door actually in the wall?? Does you object info palette allow you flip the door? It may not actually be in the wall. Check in isometric view. If not drag it out and snap it back in. Quote Link to comment
