simple rendering question
Over the years I've been wondering about this simple thing: While rendering a 3D model in RW, I can push the "esc" key to stop the rendering. However, sometimes the hotkey works, and other times it just keeps on rendering. It seems to work about 50% of the time. I've noticed this on the last several versions of VW and it is still true for VW 2015. Does anyone else have this problem ? If I'm not the only one who has this issue, is there any way to predict if the "stop rendering" hot key will work or if it won't ?
It depends, since rendering is such a system-wide resource drain, it can sometimes (depending what rendering mode you're using and the contents of your file) end up that your STOP command was registered, but has to wait for certain system resources to be freed up again before the machine can obey.
Engineering is looking for a way around this to make halting a rendering more responsive.
Same here.
Depending on Files complexity aborting a rendering can take much more time
than is acceptable while working. But I too think that ESC works reliable in 90%.
It is just not the way a user would expect.
Sometimes VW is occupied by certain tasks, so it ignores your key in - occupied
by those tasks which you want to cancel by ESC. So you have to wait for
those tasks to be done - until you can cancel those tasks ...
Especially hard if you forgot being in a RW mode and try to rotate the view.
this may refire rendering several times for that single rotation and after each
ESC-abort the next render cycle starts, with its typical ESC lag.
RW automatic re-rendering is nice for changing Camera Views for screenshots.
It works most time but it can havoc if you change to a camera, which has an
other active Layer saved in its settings, if that ever makes sense.
(Thought that's what Saved Views are for ...)
But RW automatic re-rendering is annoying in 98% of all else cases.
Like checking a material (by going into edit mode), and chosing OK without
changes, instead of pressing Cancel.
Some times certain actions cause an unavoidable re-rendering, sometimes
actions cause a error message.
Error Message to abort re-rendering sounds good at first but the only option
is to switch to wireframe - where you would prefer f.e. another mode like
Open GL - or no re-render or mode change at all - just a pause.
glad to know I'm not the only one with this problem. I also agree that it is very annoying that RW starts another re-render when you're trying to edit a texture or some other property. May I suggest the software guys try to figure out a solution to this annoyance ?
I'd like to back up the suggestion to improve abilities to cancel actions.
One day I'll learn, but I often find myself hitting update on a viewport before I'm ready. And in many of my files, there's a long lag time after I press update and before the teapot shows up, while VW is temporarily frozen. If I try to do anything during this time, VW crashes.
Likewise, sometimes I accidentally hit "edit design layer" instead of "edit annotations" in a wall section viewport, and I have to sit there while the hidden line view renders. I'm almost always unable to cancel with the escape key, or instigate a crash by hitting escape.
