Entire Leaves
Can't click on objects
Having a bit of an emergency. I am unable to click on objects on a design I am working on right now. Is there something I may have accidentally clicked or selected to cause something like this to happen?
I noticed it first when adding labels to the plants on the design. Trying to click on a group of plants it simply could not be selected. I tried changing the layer options but nothing helps. The only way I can select plant groups is to do a drag box to select the entire group (including the label). At first I thought it was just the plants layer but then I went into hardscaping and noticed that I can't select anything at all in that layer. Not even using the drag method. Same for existing trees. Strangely the only layer that is working is the bottom draft layer that I created that is basically just the ground beneath the plan.
I have been known to accidentally turn things off or click things I am not supposed to so I am hoping that this is something obvious and someone will know exactly what I did wrong.
Help! I don't have time for this nonsense!
Yes. I have tried all that. It doesn't change anything. It is very odd. A few of the plants are clickable but most are can only be accessed via dragging the select tool over the entire group. This is not a workable option though. There has to be something else.
We continue to have issues with Classes when an item (Typically a symbol) is copied pasted into a different drawing. The object looks 100% visible, yet problematic when an attempt is made to select it. Some classes appear to be on but they are not. Solution is to turn all the classes on. - Peter
Wow. OK I knew it was something stupid I had done. It WAS class options somehow set to show/snap (but not modify) others. I never use that feature. I only use layer options.
Fixed now. I noticed it when I went through all the classes turning them off and on to see if what Elite Exhibits had suggested was the problem.
I'm an idiot. I just go into full panic mode when I am behind on deadlines and something goes wrong. Thank you all for indulging me.
