simbob Posted May 11, 2015 Share Posted May 11, 2015 Does anyone know why VW would keep re-rendering? I wait 30-45 mins for a final render and then when finished it begins again automatically, it did this 3 times in a row this morning (before i cancelled it) and i don't know why. Would it be something to do with the display sleeping and what key is used to wake it? Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted May 11, 2015 Vectorworks, Inc Employee Share Posted May 11, 2015 If you're in the design layer, I have on occasion seen operations like Duplicate Array or anything that performs a series of events in a row sometimes trigger a re-render after each portion, which is not intended. Does it happen in any file or a particular one? Does it keep happening after a full reboot of the machine then returning to the same file? Quote Link to comment
simbob Posted May 11, 2015 Author Share Posted May 11, 2015 I'll have to try some of these things and get back to you. Quote Link to comment
MJADezynz Posted June 8, 2015 Share Posted June 8, 2015 This happens to my render files almost constantly, if the "Escape" key would work, it would help a lot (I understand that it is being worked on by the engineers, so hopefully will be resolved soon). I don't have to do anything but move my curser and it renders, and most of the time I can not cancel it. Quote Link to comment
Andy Broomell Posted June 10, 2015 Share Posted June 10, 2015 I would also suggest looking into rendering with viewports on Sheet Layers. Among other advantages, it helps eliminate this particular headache. Quote Link to comment
rDesign Posted June 10, 2015 Share Posted June 10, 2015 If you are in a DL and you've selected a Renderworks rendering mode other than Wireframe or OpenGL, you're basically forcing it to restart the rendering every time you touch the mouse or any key. The only way to stop the cycle, as you've discovered, is to hit the Escape key and choose Wireframe or OpenGL. In my opinion, the only rendering modes that should be used on a DL are Wireframe or OpenGL. As the others have recommended, make Sheet Layer VPs and do your renderings there, where they can be controlled predictably. Quote Link to comment
