P Retondo Posted March 2, 2003 Share Posted March 2, 2003 I just caused a crash of VW 10.1 that required me to force-quit using Task Manager. After restarting the program, all of my palettes were undocked. Restarting the computer did not cure the situation, I had to reconstruct all docking. The program froze while attempting to render a model (OpenGL mode), to which I had just added an "extrude along path" object. There were no warnings or advisories, the hourglass just persisted for several minutes in a model view that had been taking less than 5 seconds to render before adding this one object. If I render this object with no fill, I do not get a problem. If it is filled, the program hangs (apparently interminably). If I convert this object to 3D polys, rendering causes no problem with the polys filled or not. Any comments or suggestions? Seems like a bug to me. BTW, with version 10.1 docking palettes under each other is a breeze. Thanks for that fix! VWA 10.1 WinXP P4 G2.2 768 MB RAM [ 03-02-2003, 05:33 PM: Message edited by: P Retondo ] Quote Link to comment
Guest Posted March 3, 2003 Share Posted March 3, 2003 Pete, Send a link to this post and the file to me please. I'll take a look at it and send it off to the engineers if need be. tech@nemetschek.net?subject=ATTN:Katie Quote Link to comment
P Retondo Posted March 3, 2003 Author Share Posted March 3, 2003 Katie, thanks, I sent you a file. It turns out that I don't have the problem with OpenGL rendering in the "low" detail level, but do in the "high" level. Quote Link to comment
Guest Posted March 4, 2003 Share Posted March 4, 2003 OKay. I have an engineer looking into the problem. Hopefully I will have something to report back with later today. Quote Link to comment
