How to create a Poly3D on the ground plane
I've battling the for a couple of days now and can't get my head around Poly3D and then I discovered that it's GetPt3D that's throwing me off.
procedure test;
var
vec1 : vector;
h1 : handle;
begin
DSelectAll;
GetPt3D (vec1.x, vec1.y, vec1.z, false);
Poly3D (5, 0, 0, 300, 0, 0, 300, -457, 0, 33, -457, 0);
h1 := ConvertToPolyline (LNewObj);
SetPolylineVertex (h1, 2, 300, 0, 3, 90, true);
SetPolylineVertex (h1, 3, 300, -457, 3, 90, true);
end;
run (test);
In front view I get a different result with and without GetPt3D.
I want the Poly3D to be on the top view no matter what view I am in so what's going wrong?
If you test the above without GetPt3D and in any view then you get the result I want but I want to ask the user where they want the result to be after creating it.
