Laurali
elevation viewport line weights
I've printed out some elevation viewports and the line weight is way too light.
If there is a class that controls those lines as there is for sections I can't find it.
All I can think to do is trace over-but there's got o be a better way...
Select the Section Viewport, then in the Object Info Palette, click on Advanced Properties and you can adjust the line weight scaling under the Attributes tab.
Links not woking.
On 5/7/2015 at 5:52 PM, Alan Woodwell said:
Hi
If you go to this post you can see ho I set up line weights to get nice even render in hidden line and what i usually enhance in the annotation layer.
HTH
https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Main=42295&Number=210631#Post210631
Hi Allan, I'm trying to figure out the same issue. Can you update the link please? Thanks.
Steve
@Le PhamNP, Also take note of the walls, the style and exactly how the style is built. Everything is by style and wall components. The wall New or Exist Class is the Container and the Components are the Classes within the Container Wall new or Existing. Note the classes and by component. Go through the wall style ans understand it. If you dont get it exactly the same it can be very frustrating.
Use the Render style as I use. Everything is changed by class where possible.
HTH
