Macluskie Posted April 28, 2015 Share Posted April 28, 2015 (edited) Hi Here's a wee glitch that I can repeat every time in Vectorworks 2015 Can others check to see if it's my installation / machine Open a New File Start drawing a rectangle from approx 0,0 Input a large number into the floating toolbar (e.g. 5000mm x 5000mm) On my machine the rectangle will not size correctly IF I zoom out and do the same it works fine, it just seems to be a glitch if the rectangle is much much bigger than the visible Layer Plane Screen. Cheers Steve Edited April 28, 2015 by Macluskie Quote Link to comment
Benson Shaw Posted April 29, 2015 Share Posted April 29, 2015 (edited) Confirmed on my system. I used 10' x 10' rather than 5000mm x 5000mm input by tabbing into the floating data bar. New file scale is 1:1. Starting zoom is 100% Rectangle does not execute the data input if x or y dimension is equal to or greater than 5'. If value is less than 5', the tabbed dimensions function as expected. Circle (radius mode) behaves similarly. If input R is equal to or greater than 7.5', the circle draws with R= cursor position when the tab key is pressed. At 80% zoom, input fails to control rectangle dimension input value is equal or greater than 7.1''. Tab into second data field after entering the r value. It is probably different values for different zoom % -B Edited April 29, 2015 by Benson Shaw Quote Link to comment
