jet Posted April 27, 2015 Share Posted April 27, 2015 I am doing a survey plan, and measureing the angle of lines, i want 0 deg to be north, currently 0 is east. I am sure there is a way to change that, but i can't find it! any help out there would be appreciated. cheers, jim using VW design series 2015 on 2011 15" MBP Quote Link to comment
AlanW Posted April 27, 2015 Share Posted April 27, 2015 If you use the Property line tool and select bearing this should be set to N 0°00'00" E, so the first line you type without changing any angle will be north. you use angles relative to north as per the survey. Just leave the N & E as is and just type in the angle and distance, so going east will be N 90°00'00" E south will be N 180°00'00" E etc Quote Link to comment
jet Posted April 27, 2015 Author Share Posted April 27, 2015 True, but what i have is a series of lines that i have to give the length and angle for. Lines that i want to be an angle of 270 degrees are measuring 0. Another example a line that i want to measure 180 degrees is measuring -90. Quote Link to comment
AlanW Posted April 28, 2015 Share Posted April 28, 2015 Try this movie maybe it will answer your question. 1 Quote Link to comment
