ScottBFM Posted April 27, 2015 Share Posted April 27, 2015 I'm drawing a wall that needs components that can be turned on and off regularly throughout the project. I have a wall of 5 1/4" thickness that I will show as framed (3 1/2) by turning off my wall finish class. The issue: doors in this wall are showing a line at the jamb that assumes the wall finishes are still showing- thus, a 5 1/4" line at the jamb on a 3 1/2" wall. I've turned off every class in 2d vis/classes except door leaf and swing and still can't get that line to go away. How can I get rid of it? Quote Link to comment
AlanW Posted April 27, 2015 Share Posted April 27, 2015 (edited) Is it the ceiling line class from the walls?? This is a class that you turn on to see the door head when doing a ceiling plan. To find out what it is you explode the complete door detail and look at what all the pieces are and you will find the offending item. Edited April 28, 2015 by Alan Woodwell Quote Link to comment
