Example for vs.AlignDistribute2D(MenuAction, AlignDist2DParms)
DomC
Hi
I try to use this Function, but failing by fuguring out the right parameters/variables. I do not understand if i have to get the Variables from an other action/function or if I just missing the right values.
Very nice if anyone could help
Thanks
This is, what the FunctionReference says:
VectorScript Reference.html
PROCEDURE AlignDistribute2D
( MenuAction :LONGINT;
AlignDist2DParms :LONGINT
Python:
def vs.AlignDistribute2D(MenuAction, AlignDist2DParms):
return None
or here:
Python:
AlignDist2DParms = vs.AlignDistribute2D(MenuAction)
I try to do, something in this direction (Script to Distribute, with a fix offset by expanding the limits):
import vs
links,rechts,unten,oben,xtotal,ytotal=0,0,0,0,0,0
anzahl=vs.NumSelectedObjects()
# Box auslesen und x, y ausgeben
def xy():
p1,p2=vs.GetBBox(h)
x=abs(p1[0]-p2[0])
y=abs(p1[1]-p2[1])
xmin=p1[0];	xmax=p2[0]; ymin=p1[1]; ymax=p2[1]
return(x,y,xmin,xmax,ymin,ymax)
#vs.AlrtDialog(anzahl)
i=1
h=vs.FSActLayer()
while h != None and i <= anzahl:
x,y,xmin,xmax,ymin,ymax=xy()
if links>xmin:
	links=xmin
if rechts		rechts=xmax
if unten>ymin:
	unten=ymin
if oben		oben=ymax
#vs.AlrtDialog(xmin,' ', xmax)
xtotal=xtotal+x
ytotal=ytotal+y
h=vs.NextSObj(h)
i+=1
rx_abs=links+xtotal
vs.Locus(rx_abs,0)
# vs.AlignDistribute2D(??)  #??????
vs.LNewObj(h)
vs.DelObject(h)
Edited by DomC
  • 3 weeks later...
Hello DomC,
I looked into this: it's a broken procedure (does nothing at best) and is wrongly declared on Dev (actually is wrongly defined in its library). Thank you for pointing this out, I report it now as bug.
Please implement your own procedure using other functions.
Ciao!
orso
