Benson Shaw
Publish is rasterizing text
Just noticed that my Published to pdf sheets always have rasterized text. The option for rasterize text is disabled in dialog for each sheet.
To test, I enabled the option, published (= rasterized text), then disabled the option and published again. Same result. Text is rasterized.
Export or Print to pdf produces unrasterized text, as expected.
Did I miss a Publish setting or pref?
Thanks!
-B
I am unable to replicate this on Windows or Mac.
If you create a new blank file and add a single text object, then viewport it to a sheet layer and publish or save a view of it and publish with Rasterize Text off, does it still do it?
Yes. Still happens. - Attached is vwx created after system restart, and pdf created via Publish.
Publish options for pdf of this sheet layer have disabled the Rasterize Text.
Some other setting or pref?
-B
Hi,
On the export panel I Have un-ticked the rasterize text box and I get this. Appears to be un-rasterized.
Thanks for looking , Alan! Are you using Publish or Export?
Export works as expected.
In Publish, I have the box unticked, and still get the rasterized output.
-B
Export and publish from your file and got the same results.
Both appeared to be NOT rasterized like my previous post.
Edited by Alan Woodwell
Same meaning as your previous? or same as my results?
PDF text is rasterized from Publish?
Anyway, thanks.
My pdf text is always rasterized from Publish. Whether I check or uncheck the Rasterize Text option makes no difference. Export and Print to PDF the text is not rasterized.
-B
Sorry the forgot to include the files.
Both export and publish from your file produced the un-rasterized result.
I have this same problem on my iMac.
Publish rasterizes the PDF. Print to PDF works correctly.
I'm switching to VW 2015 from VW 2013 and
mac mini 2009 to iMac late 2013
henry
Henry - a theory:
It's the font! I'm using Avant Garde. If I switch to Geneva, or Century Gothic, or several others, the text is not rasterized.
But this is new to v2015 and mac OS10.9.5. Avant Garde was not rasterized by Publish in v2014 w/10.6.8
Font Book indicates a name table error. I'll see if I can find a new Avant Garde and try that.
-B
A font-specific issue would make sense since myself and others testing that same file didn't get the same result. Especially if FontBook is popping an error up.
If the font was installed on an earlier OS and migrated over to the newer 10.9, it could have become corrupted during that as well, I see that fairly regularly especially if it was upgraded multiple times.
Sometimes just a reinstall of the font cures it.
Also, the problem font is in my user>library >fonts folder, not the system>library>fonts folder. Does the publish command access user and system fonts? or only the system ones?
-B
