tinwid Posted April 23, 2015 Share Posted April 23, 2015 Hello everyone I'm using Vectorworks 2015 at university. I have created a site model and then I referenced a housing model using viewports. Now when I'm trying to create a section viewport that cuts through both the site and the model appears empty - a rectangle with a red cross in it. I have checked the visibility of the layers/classes and the 'save viewport cache' function is turned on. Does anyone know what can be an issue ? It worked perfectly fine at the beginning with a first model though. I saved the model under a different name with a few changes and referenced it back - the same way as the previous one. I'm using MacBook Pro 13, mid 2014 - the basic version Any thoughts/advice would be appreciated! Thanks guys Quote Link to comment
AlanW Posted April 23, 2015 Share Posted April 23, 2015 (edited) Ok You have changed the reference name then the computer cant find it, so you have to go to and re-link the reference. Go to the Organization Pallet and Reference and edit and browse to the new file and it will re-link. HTH Edited April 23, 2015 by Alan Woodwell Quote Link to comment
tinwid Posted April 23, 2015 Author Share Posted April 23, 2015 I meant that the layer and classes of the site on which building is situated are on. sorry for confusion Quote Link to comment
AlanW Posted April 23, 2015 Share Posted April 23, 2015 (edited) If all else fails redo the section viewport again and often it all reappears some issue with something. Had it happen a few times before and restarting VW can also fix it. Edited April 23, 2015 by Alan Woodwell Quote Link to comment
tinwid Posted April 23, 2015 Author Share Posted April 23, 2015 I have already redone the section viewport several times, no difference though. I will try restarting vectorworks though Quote Link to comment
CipesDesign Posted April 24, 2015 Share Posted April 24, 2015 The red border signifies that the VP (or Site Model) needs to be Updated. Select it and click the Update button in the Object Info Palette. Also, check to make sure that all elevation (Z heights) are set properly in both the Site Model and the referenced file. In other words, make sure that the elevation of the houses will properly coincide with the elevation of the Site Model. Quote Link to comment
AlanW Posted April 24, 2015 Share Posted April 24, 2015 Check that your design layers are the same scale. Quote Link to comment
Kevin McAllister Posted April 24, 2015 Share Posted April 24, 2015 (edited) The rectangle with the red cross means that VW can't find anything to display in the viewport. Are you sure that you're checking the layer and class visibility associated with the viewport rather than with the overall design layers of the document? You find these settings in the Object Info Palette when the Section Viewport is selected. (See attached image) Are you objected within symbols? Are the classes for both the objects in the symbol and the symbol itself turned on? With a site model its possible to break down the various parts into different classes. Are you sure all of the appropriate classes plus the container class (i.e.. the one holding the model itself) are all turned on? With the site model selected you can click on Site Model Settings in the OIP and then Graphic Properties in the bottom left of the dialog that comes up to see the classing. If you're referencing, are the appropriate layers and classes turned on for both the reference viewport and the section viewport? Kevin Edited April 24, 2015 by Kevin McAllister Quote Link to comment
