Import SketchUp problems
OK here's a little more:
The error message:
Problemsignatur:
Problemhändelsens namn: APPCRASH
Programnamn: SketchUpWorker.exe
Programversion: 0.0.0.0
Programtidsstämpel: 55005381
Namn på felmodul: SketchUpWorker.exe
Modulens version: 0.0.0.0
Tidsstämpel för felmodul: 55005381
Undantagskod: c0000005
Undantagsförskjutning: 000000000001465e
OS-version: 6.1.7601.2.1.0.256.48
Språkvariant-ID: 1053
Ytterligare information 1: bab3
Ytterligare information 2: bab30863d3a16f1b446d293cc6b9dbda
Ytterligare information 3: ea93
Ytterligare information 4: ea938fecf28aa4ee8e9c933d7bbed529
Edited by Vincent C
Does this happen on more than one machine, but all of those machines with that language setting? Does the issue appear on any Windows 7 machines with an alternate language?
I am unable to reproduce the issue here, but have had MANY random crashes where the common factor was the OS language setting.
Don't know, it works on my Mac which is 'Swedish'.
(I just started at this office, they use Autodesk but I need to finish off some existing projects so I installed VWs on my office machine over there and subsequently got this problem, I'm not saying it is a Windows thing but I sure am getting a lot of small irritating jinxes all around giving me flashbacks to my time prior to Mac
I'll try to set the language to English ad see if it helps......
Edited by Vincent C
  • 11 months later...
Following-up and adding on to this thread - it seems that something has changed in the file format used by Sketchup 2016, as I'm having the same problem and a similar sketchupworker.exe crash; trying the same file on a Mac results in no crash, but nothing imports.
For giggles, I tried importing the same file into Capture Argo, and it too threw an error and considered the file corrupted.
Nemetschek's aware of the bug - I have already corresponded with Tech Support about it - so hopefully we'll see a fix sometime!
In the meantime, the workaround seems to be to save the file as a 'Sketchup 2015' or earlier file, which imports just fine.
Hope this helps someone else who stumbles across the same problem!
