Nedly Posted April 21, 2015 Share Posted April 21, 2015 I've built a site model and am trying to insert a closed rectangular retaining wall (like for a basement). I keep getting an error message; "two intersecting pads." I've set the outside grade line to follow the terrain and the interior grade (pad) to be at zero (offset to bot of wall). I've also been careful to update the model (which is when the error message apprears). After trying everything I can think of (fairly limited and new to VW) to correct this issue, I still can't get it. Thoughts? Many thanks. Quote Link to comment
Benson Shaw Posted April 22, 2015 Share Posted April 22, 2015 (edited) Is there a stacked copy of the pad or the grader? inadvertent Duplicate in Place? Cut then Paste in Place if no copy. Or Delete then Undo. Is the outside grade line actually a Grade Limit (Site Modifier pulldown near top of OIP)? If it's a pad or other, change the object type in the OIP pulldown. Is the grade limit bigger than the pad and completely outside the pad? If not, adjust so that both those conditions are met. Grade Limit can be any size or shape as long as all of it is outside all of the pad. It can be as close to the pad as you like as long as it's not coincident or overlapping anywhere. Or maybe it's something else. -B Edited April 22, 2015 by Benson Shaw Quote Link to comment
Nedly Posted April 22, 2015 Author Share Posted April 22, 2015 Thanks. No stack, No duplicate. Can't see the Grade Limit (Site Modifier Pulldown) near top of OIP ) or anywhere). Not coincident or overlapping anywhere that I can tell. Have tried help menu, online tutorials with no luck. Hmmmmm... Quote Link to comment
