Benjamin Weill Posted April 18, 2015 Share Posted April 18, 2015 Hi, Does anyone know if it's possible to have a record format populate from a symbol's location? for example, I have a symbol in my template file for a line set schedule, that is itself made up multiple instances of another symbol for each individual line set. The individual lineset symbol has a record that lets me fill in it's distance from plaster line, it's line set number and what's on it. is it possible to have the record for the distance from PL auto populate with the symbol's "Y" coordinate? That way I don't have to type it in twice whenever I set up a lineset schedule for a new venue - once in the symbol's "Y" coordinate field, and again in the record's "dist from PL" field. Thanks Quote Link to comment
michaelk Posted April 19, 2015 Share Posted April 19, 2015 There's not a built in way to do it. But it's not too hard. I suppose you could make all your linesets be lighting instruments. I don't remember if the field was added in 2015 or 2014, but you can call the field ='Lighting Device'.'Y Location' in any lighting device. But that's sort of a hack. I use a super simple trick for this very problem. In the worksheet have a column formatted as a dimension that calls the record format and field for the lineset distance to plaster line. Add an additional temporary column that calls =YCOORDINATE*12 Select all the database cells in the temporary column. Copy. Select all the database cells in the record format.distance to plaster line column. Paste. Since the linesets rarely move, you only have to do it once. hth mk Quote Link to comment
RickR Posted April 27, 2015 Share Posted April 27, 2015 There is nothing about lighting fixtures that helps this. I do it all the time with a variety of curtain and batten symbols in a worksheet rather than some other object. In the worksheet just limit the classes to the ones used for rigging gear. the Xcoordinate & Ycoordinate functions work on any object type. I always like to place my origin at the plaster line for just this purpose. However you could add the differential if you wanted something else. I recall posting some worksheets in the sharing folders some years ago. If you need help, just ask. Quote Link to comment
Benjamin Weill Posted April 28, 2015 Author Share Posted April 28, 2015 RickR, I don't actually use worksheets that often, I'd any help you could offer. Thanks Quote Link to comment
RickR Posted May 21, 2015 Share Posted May 21, 2015 Sorry it's been a while since I checked in here. Try some of the worksheets in this file, particularly the pipe and curtain schedules. Some of the fixture ones also have location fields just to help sorting. Be sure to see the 'sticky' post in the general forum. Worksheets have some interesting tricks available. https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=111911#Post111911 Quote Link to comment
SamIWas Posted June 14, 2015 Share Posted June 14, 2015 Hi, Does anyone know if it's possible to have a record format populate from a symbol's location? for example, I have a symbol in my template file for a line set schedule, that is itself made up multiple instances of another symbol for each individual line set. The individual lineset symbol has a record that lets me fill in it's distance from plaster line, it's line set number and what's on it. is it possible to have the record for the distance from PL auto populate with the symbol's "Y" coordinate? That way I don't have to type it in twice whenever I set up a lineset schedule for a new venue - once in the symbol's "Y" coordinate field, and again in the record's "dist from PL" field. Thanks I did something much like this simply writing a small VectorScript. However, I don't know if this would work for symbols within another symbol. But, it would be fairly simple with just the multiple line set symbols. Quote Link to comment
Benjamin Weill Posted June 16, 2015 Author Share Posted June 16, 2015 I did something much like this simply writing a small VectorScript. However, I don't know if this would work for symbols within another symbol. But, it would be fairly simple with just the multiple line set symbols. Do you still have the script? I don't have a lot of experience using scripts. It'd be great to see how it worked. Thanks!! Quote Link to comment
Hippocode Posted July 6, 2015 Share Posted July 6, 2015 Hi, I've got a plug-in that can do that. I'm linking the similar topic. https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=212560#Post212560 Quote Link to comment
