WhoCanDo Posted April 16, 2015 Share Posted April 16, 2015 Isn't GetLine3D suppose to pick points from different Z planes? I have a Locus on Z+200, Z0, Z-200 & X100,Z0 If I run the following macro then I can pick any locus first but no other if I am in any view other than iso and then only the one on the Z0 plane. Surely I should be able to pick any loci being this is a 3D tool and set to False. Can anyone suggest a reason for this or a way around this? procedure test_this; var p1X, p1Y, p1Z, p2X, p2Y, p2Z : real; begin GetLine3D (p1X, p1Y, p1Z, p2X, p2Y, p2Z, false); Poly3D (p1X, p1Y, p1Z, p2X, p2Y, p2Z); end; run (test_this); Quote Link to comment
MullinRJ Posted April 16, 2015 Share Posted April 16, 2015 Mr. Do, Yes, it is broken, or better yet, never worked. I've been playing with it for a day now (since your previous thread) and from VW 2010, when it was introduced, to VW 2015 it never worked. The Z components are always 0. GetPt3D() seems to be equally afflicted. To get 3D points interactively try: ********* procedure Get3DPt(var P :Vector); Begin CallTool(-316); { 3D Locus tool } GetLocus3D(LActLayer, P.x, P.y, P.z); DelObject(LActLayer); End; { Get3DPt } ... BEGIN Get3DPt(P1); Get3DPt(P2); ... ********* This won't give you the rubberband effect of GetLine3D, but it will work with 2 clicks. You can thank Gerard Jonker for suggesting this method years ago. Raymond Quote Link to comment
