CustTool does not return to None Class
SIDUG
Good morning to all:
I have a custom tool script that execute text command. Unlike my other scripts, after execution it doesn't return to the previous class 'None'. i.e. it will stay in ''A Note' class. That creates a bit of problem since some of the objects I create after that would be in a class which I don't want. I know I can try to remember to manually switch back to 'None' but why is it not acting like my other scripts? Much appreciation for a solution.
Procedure CustTool;
VAR
Result:BOOLEAN;
BEGIN
PushAttrs;
FillFore(32);
FillBack(0);
FillPat(1);
PenFore(257);
PenBack(0);
PenPat(2);
TextFont(50);
TextSize(9);
TextFace([]);
TextSpace(2);
TextJust(1);
NameClass('A NOTE');
SetTool(-200);
PopAttrs;
END;
Run(CustTool);
best regards
Sidug
Could it be that the call to the text tool doesn't return you to the plugin script after the task appears finished? resulting in the PopAttrs; not being executed. I think you need to use CallTool(); instead of SetTool();
You could test this in one of two ways. By sending a Message('positive progress');
to yourself after the SetTool(); statement. If it doesn't pop up and you need to use SetTool(); you'll need to approach the task in a different manner.
Another way to specifically deal with the active class setting is by capturing the active class at the start and resetting it at the end of the script.
VAR
activeClName:STRING;
BEGIN
PushAttrs;
activeClName:= ActiveClass;
{the PIO script}
PopAttrs;
NameClass(activeClName);
END;
Larry
Edited by LarryO
