Pat Stanford 1,525 Posted April 3, 2015 In response to a post on the General Discussion, I put this script together. It will copy the data in the Dimension String of a Dimension object into a user attached Record named "DimFomat" and Field named "MyField". Change the Const values to whatever you need. The thread that started this is https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=209786#Post209786 Procedure DimToRecordField; {Written in response to a request on the General Discussion Forum} {© Pat Stanford, April 2, 2015, Released into the Public Domain. No Rights Reserved} {Change the DimRecord and TheField constants to match your record and field names} {Script store the data from the DimText into a user attached record and field} Const DimRecord='DimFormat'; TheField='MyField'; Function HasRecord(H1:Handle; RecordName:String):Boolean; Var N1:Integer; Begin HasRecord:=False; For N1:= 1 to NumRecords(H1) do Begin If GetName(GetRecord(H1, N1))=DimRecord then HasRecord:=True; End; {You could add code here to SetRecord if you wanted to add the record} { to items that don't have it already attached} End; Procedure Execute(H1:Handle); Begin If HasRecord(H1,DimRecord) then SetRField(H1,DimRecord,TheField,GetDimText(H1)); End; Begin ForEachObject(Execute, (((T=DIMENSION) & (SEL=TRUE)))); End; Run(DimToRecordField); Quote Share this post Link to post
