Count Strings in Worksheet
Hello all,
I was wondering if there was a way to count strings in a worksheet? The values are not in under a database row, they are just punched in stings to cells. I've tried nesting them in "INT" or "Value" functions and using them with "COUNT" or "SUM" functions but to be honest a bit frustrated that I can't even figure out this. What would you suggest?
EDIT: my strings are basically dates in this format; mm/dd/yy
Edited by sle7en7
If what you want is just to know that a cell has data you can use an extra column with an IF statement.
IF(A2='',0,1)
What this says in English is that if there is nothing in cell A2 then use a value of zero for this cell, otherwise use a value of one for this cell.
You should then be able to use a Count function to get the total you are looking for.
