Assigning parameter to DYNARRAY issue
LarryO
It would appear that assigning a parameter to a dynarray of char is not possible. My parameter PSizeH4L is up to 16 characters long from a predefined pop-up list.
The assignment := in following doesn't seem to pass a value:
VAR
StudLength:DYNARRAY[]OF CHAR;
BEGIN
StudLength:=PSizeH4L;
DELETE(StudLength,1,6);
MESSAGE('Length= ',Studlength);
END;
BUT the following does work
VAR
StudLength:ARRAY[1..16]OF CHAR;
TempDynArray:DYNARRAY[]OF CHAR;
BEGIN
TempDynArray:=StudLength;
Delete(TempDynArray,1,6);
StudLength:=TempDynArray;
END;
Also is there some reason that
ALLOCATE TempDynArray[1..16];
crashes VW2013 when used in a point plugin object?
Thanks.
DYNARRAY[]OF CHAR will automatically allocate itself. It's probably crashing because they system and you are both trying to control the space allocation.
I did a quick test in 2015 and I did not see any issues assigning a parameter value to a Dynarray of Char.
tempshape : Dynarray[] of Char;
tempshape := pShape;
AlrtDialog(tempshape);
I'm not doing any character manipulation but the simple assignment works correctly in 2015.
Thanks Kevin.
It must be some quirk in VW2013. The work around will have to do. I'll just need to remember if I have a similar situation in the future. I took 3-4 hours to investigate thinking I made some kind of mistake, even though the complete script compiles without error. With the exception of attempting to allocate the variable some memory before its first use. That crashed VWs as soon as I closed the script window.
