P Retondo Posted February 23, 2003 Share Posted February 23, 2003 The new pocket door PIO is much, much better than it used to be. The pocket draws correctly, and all of the object attributes seem to work well. I have the .vso version dated 2-11-03, and it still has two significant glitches in the 2D department: 1) The wall outline is drawn with a very thin lineweight. The pocket outline is okay, it's the outside wall line that is incorrect. 2) Also, the walls of the pocket should have the same fill color (and other attibutes) as the wall! Is there any workaround for these problems, or do I just have to create some walls and fill overlays to make this look right? Quote Link to comment
