  • 2
nurbs/line preferences, normals align
Bas Vellekoop
I hope it is possible
1. to make quick preference for:
- show vertices
- show normal
- show direction
And make it available as an button in the tool bar.
It would be useful if this was stored as an Vectorworks preference
2.
It would be very helpful if there was a possibility to automatic align normals in the create fillet surface menu.
Allot of times I get the 'fillet surface could not be created' window because I mirrored a surface and by doing that the normals aren't aligned anymore.
3.
able to use the connect/combine tool on trimmed nurbs surfaces
4.
The possibility to align the normals to the same side when using the shell solid tool (so that the nurbs surfaces extrude to the same side)
5.
ability to change several 3D poly`s or polygon's at once to nurbs surfaces instead of one by one.
Edited by Buzz Lightyear
1 answer to this question
