Create NURBS surface failed
I created a NURBS surface from two identical NURBS curves spaced 15' apart, (one copied above the other)
I'm able to edit all the vertices without a problem except one, or maybe it's 2 that are congruent?
How do i solve this issue? Attached is the file. The vertex in question is on the far left.
Thank you.
It is two coincident vertices. A stack. They are probably the end points of your source NURBS curves.
Select the NURBS Surface with the Reshape Tool, drag a marquee around the stubborn points and release. This selects both/all the vertices in the stack. Drag to move them together. Be careful not to include other vertices in the marquee.
Good luck!
-B
Edited by Benson Shaw
