visard Posted March 19, 2015 Share Posted March 19, 2015 (edited) This must be a dumb question but here goes: I'm trying to make a two vertical panel door with transom above - I can't seem to find a way to line up the transom with the door vertically or seal the frame between them without making a full depth transom sash.(?) I believe I've dialed up the proper panel settings with no two panel result? Suggestions welcome. Thanks ...Would add image if I could figure out how to attach. Edited March 19, 2015 by visard Quote Link to comment
CipesDesign Posted March 19, 2015 Share Posted March 19, 2015 Hi Visard, an image would be very helpful here. Click on Full Screen Reply (below), then click on File Manager, then Choose File, Then Add File, Then Done... Yes it's awfully tedious, but that's the way to do it... Quote Link to comment
visard Posted March 19, 2015 Author Share Posted March 19, 2015 See attached image Quote Link to comment
CipesDesign Posted March 19, 2015 Share Posted March 19, 2015 Hmm. OK for the Door Leaf, try using one (1) vertical Muntin. To make the transom glazing align with the door glazing try increasing the width of the sash (which will also make the top and bottom transom sash wider, which may not be desirable). If all else fails, you can use a (separate) Window in the wall above the Door. Not my favorite way to do it for a number of reasons, but it might give you the control you need to get the modeling/rendering accomplished... Post back if you have further questions. Quote Link to comment
Markvl Posted March 20, 2015 Share Posted March 20, 2015 Doors and Windows have lots to be desired in Vectorworks but that is for another forum. You could model something out along with the door but of course this does take more time but...you get the look you want. Simply turn the model and door into a symbol. I've had to do this in some circumstances but once its done you've got it for other projects. Quote Link to comment
