MattG Posted March 11, 2015 Share Posted March 11, 2015 Is there some cool way of having a document put some sort of text somewhere on the sheet that labels the sheet layer name? I have a co worker who uses the date stamp tool and in a perfect world he would like that to have a field in there that displayed the sheet layer name on it. Or maybe a field in a title block that you can link text to a record, but that record value would be the sheet layer name. Or any other potential idea someone has or uses to achieve this. Anyone out there have any good ideas on a way to do this? Matt Quote Link to comment
Kevin McAllister Posted March 11, 2015 Share Posted March 11, 2015 (edited) Check out the included default title blocks. There are some that will do this. You need to create a title block record that references _SN and _SD. Search for Custom Title Block in the Vectorworks help for a detailed explanation. http://app-help.nemetschek.net/2015/NNA/eng/VW2015_Guide/Setup/Creating_a_Custom_Title_Block.htm?rhsearch=custom%20title%20blocks&rhsyns=%20symbol Note that Automatic Drawing Co-ordination needs to be turned on under File>Document Settings>Document Preferences. Kevin Edited March 11, 2015 by Kevin McAllister Quote Link to comment
