PWalters Posted March 7, 2015 Share Posted March 7, 2015 Is there anyway to free rotate an object, rather than guessing at the degree turn? Quote Link to comment
Pat Stanford Posted March 7, 2015 Share Posted March 7, 2015 Have you looked at the Rotate tool in the Basic Tool Palette? Select the object then Rotate tool. Click to set the center of rotation. Click again to give yourself a "lever arm" to use to rotate. move the cursor to get the rotation you want. Click a third time to finalize the rotation. Quote Link to comment
PWalters Posted May 17, 2015 Author Share Posted May 17, 2015 Thank you. I hadn't looked at that rotation tool. I've done as you said and I can see the protractor tool (light blue).I spin it, click again, and nothing happens. ? Quote Link to comment
AlanW Posted May 17, 2015 Share Posted May 17, 2015 Did you select the item first? Select the item and when you get the lever arm hit the tab key and you can tab along and type in the angle you need. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted May 18, 2015 Vectorworks, Inc Employee Share Posted May 18, 2015 Have a look: Quote Link to comment
