AN Design Posted March 27, 2015 Share Posted March 27, 2015 I too am experiencing sudden crashes w/ SP2, happens most often w/ paste in place as well as selection of a wall or text and then hitting copy. Quote Link to comment
csousawy Posted April 2, 2015 Author Share Posted April 2, 2015 (edited) Updating my video card driver seemed to help quite a bit. That cut down my crashes to one or two a day from one every 15mins or so. SP3 seems to be helping too so far. Only one or two crashes since updating. -CSW Edited April 2, 2015 by csousawy Quote Link to comment
Administrator JuanP Posted April 2, 2015 Administrator Share Posted April 2, 2015 Please make sure to update to our latest 2015 SP3. http://www.vectorworks.net/downloads/ServicePack.php?major=2015&servicepack=3 Quote Link to comment
AlanW Posted April 2, 2015 Share Posted April 2, 2015 Hi, Just had an issue with VW2015 crashing instantly when trying to render a viewport on a large file. Worked well in 2008 but 2015, Bang.... Sent file to VW tech in Australia and after a while sent it to USA and between the 2 they figured out that I had drawn some fences using tapered extrude objects. They suggested I delete them and Bingo, all good. This is because a solid modeling kernel was changed to Parasolid in Vw 2009. This is a much more robust solids engine but it is also more strict in the base geometry it will accept. It doesn't like those tapered extrudes and so fails to section them. Generally speaking, you need to create tapered extrudes from planar 3D polygons, which was not the case here. So check your files or send off to VW teck. They were amazingly responsive, had a solution in 2 days, saved a lot of time at work and headaches. Quote Link to comment
csousawy Posted May 5, 2015 Author Share Posted May 5, 2015 Yes, SP 3 seems better. Sometimes sending files to VW tech support isn't an option. Especially when working with NDA, etc. Quote Link to comment
