Vince Oles Posted February 26, 2015 Share Posted February 26, 2015 I'm dimensioning a floor plan viewport in Annotation mode and the horizontal dimensions display ok but vertical dimensions show only leader lines and blank box where dimension should display. I checked settings in Class Organization...seems to be ok. Thanks in advance for any suggestions! Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted February 26, 2015 Vectorworks, Inc Employee Share Posted February 26, 2015 Well the class visibilities for a viewport's annotations aren't controlled by Organization, they're controlled in " Classes..." in the viewport's Object Info palette, is that where you verified the visibility? Also, is it just some viewports that you don't see the text in? If you dimension right on the sheet layer, do those dimensions appear correctly? Quote Link to comment
Vince Oles Posted February 26, 2015 Author Share Posted February 26, 2015 The dimension class is visible in the viewport OI box. Dimensioning directly on the sheet layer has the same issue...no dimension showing in the vertical direction. The Text rotation box is set to the default "Aligned". If I switch to "horizontal" the text will appear but it's a bit awkward looking for a string of vertical dimensions. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted February 26, 2015 Vectorworks, Inc Employee Share Posted February 26, 2015 Does any font have this same issue? Could you please post a file with a sample of the problem in it? I can take a closer look. Quote Link to comment
Vince Oles Posted February 26, 2015 Author Share Posted February 26, 2015 Font selected is Arial. Same issue with other fonts. Also, if I save as pdf, fonts will reappear. I sent file to tech support. Quote Link to comment
