johnharley
Property line notes
I have been using the property line tool. This is a great feature, very easy to use. However, when using the "label" option, the bearing is printed on one side of the line and distance is printed on the other. The two notations are not equi-distant from the line (the "inner" note is always set back farther) and it looks a bit strange. How can I make the two notations equal distant? Or (better) how could I put them both on the outside but spaced apart?
One final question on notation. How can I get bearings written using degree-minute-second symbols? Instead of "d-m-s'. Thanks
Hi John,
While there is no way to control the formatting of property line labels, currently, you can set the two notations to be equi-distant from the line . Once you have finished the property line, select the property group or text objects and change the text vertical alignment from top to center in the text menu.
I'll put your other suggestions into our wish list for a future release.
Thanks and hth,
Frank BraultNemtschek N.A.
