3D Scan Input & Object Manipulation
Hi all
I have a scan of a 3D object in .STL format
I can use Meshlab to create a .3DS or .DXF, both of which I can import into Vectorworks 2015
The question is how to then manipulate the resulting model which imports as an incredibly complex mesh or incredibly complex (33000+) tiny polygons
Is there any way to turn this object into something which is able to be manipulated with the standard 3D tools? (Deform, Fillet etc)
Thanks all
Mac
As far as I am aware, no. If anyone DOES know of a method, I would personally be very interested in it as well.
Vectorworks has no good solution for dealing with complex meshes from any other source, there is work being done on this, especially since it is required in order to deal with point clouds and direct import of 3D scan STLs (exactly like you have) but I haven't seen anything from it yet.
  • 2 months later...
