schreib Posted February 19, 2015 Share Posted February 19, 2015 how about USA wall types? any to share? Quote Link to comment
Guest Wes Gardner Posted April 1, 2015 Share Posted April 1, 2015 I have two... One is set up to function with levels, layers and stories - it has a plus sign as a prefix. It will need levels set up for it to bind to... The other is set up to function without levels and stories - you'll need to supply a Wall Height for the layer it is placed on. Quote Link to comment
michaelk Posted April 1, 2015 Share Posted April 1, 2015 Wes Interesting… Do you make a duplicate wall type with the sheathing and siding components having a different offset for each different slab thickness? Quote Link to comment
Guest Wes Gardner Posted April 2, 2015 Share Posted April 2, 2015 If you use the style that DOES NOT use levels then, yes you will need to adjust that offset... Quote Link to comment
Guest Wes Gardner Posted April 2, 2015 Share Posted April 2, 2015 (edited) I'll post this here as well as it steps you through how to create a wall style from scratch and also talks about the three methods for setting up a wall style. Edited April 2, 2015 by Wes Gardner Quote Link to comment
Christian Fekete Posted February 1, 2016 Share Posted February 1, 2016 Would you pleas share in vw 13? Thank you Quote Link to comment
Christian Fekete Posted February 3, 2016 Share Posted February 3, 2016 great worksheet thank you Quote Link to comment
lcda Posted February 11, 2016 Share Posted February 11, 2016 does any one knows how to do a brick wall hatch like this Quote Link to comment
Christian Fekete Posted March 3, 2016 Share Posted March 3, 2016 That's too many details, walls in VW are defined in thicknesses with individual heights as needed but I don't think you can add two thicknesses above one another Quote Link to comment
